best tires
Old 05-06-2007, 08:41 PM
jtimports's Avatar
Default RE: best tires
im on 33s Pro Comps, ATs. They are a nice daily driver tire, very quiet too..
  #12
Old 09-08-2013, 03:07 PM
rhettjstone's Avatar
Mine doesn't get off-road very often...so I went to SimpleTire.com and got a set of Michelin Pilot Alpins. I really like em a lot. Great all-season tire, quiet, good road manners.
  #13
Old 10-02-2013, 04:28 AM
runnerguy's Avatar
To me, Terra Grapplers are one of the best all around tires. Good traction on and off the road.
  #14
Old 02-13-2014, 10:26 AM
jgue498's Avatar
Default Hankook DynaPro ATM
I've got about 20k on a set of 265/70/16s. They are very quite & smooth on the highway Yet can do some any offroad situation a stock 3rd gen 4runner can do including moderate mudding, hence the ATM (all terrain & mud). Never gotten stuck, they just keep plowing ahead. They clean themselves on the go in the mud, wear very well and best of all, look beefy as they come about 7% wider than a normal 265s and also have 6 plies so cactus isn't much of an issue. About $600 installed. You will like them.
  #15
Old 05-07-2014, 06:58 PM
Mitersell's Avatar
The T800 depicted would be a good choice. Tow pin/clevis at front, just need a connector rig(of your own) to the pulling unit, good ground clearance to the fuel system and batteries/steps. 18 spd is a bit overkill but useful as is the 4 way lockup, that is two differential locks and a power divider lock. HP is a bit hefty but you don't have to use all of it and the 16 k front with 46k rears is a good choice for stability and weight bearing.
  #16
Old 12-07-2014, 06:52 PM
sidewinder's Avatar
Member
General Grabber series would be my suggestion it has some off road capabilities.
  #17
Old 03-26-2017, 04:46 PM
DonnyJ's Avatar
Pro Comp has some A/T Sport tires that are pretty aggressive for off-road but still appropriate for daily use. If you look online you can usually find some good deals on tire packages.
  #18
Old 11-25-2022, 11:06 AM
fahad0's Avatar
Default wheelsrush
A set of good tires is very important to keep vehicle performance on its peak. I have a toyota tacoma pickup truck and i find best tires from this post. Read Here
carid
03-28-2019 09:55 AM
carid
12-01-2017 08:43 AM
marcel
01-14-2010 12:57 PM
Roosterboy
10-17-2007 03:53 PM
keyont
09-28-2006 10:34 AM
Quick Reply: best tires
