-   Audio/Visual Electronics (https://www.4runnerforum.com/forum/audio-visual-electronics-10/)
-   -   key fob (https://www.4runnerforum.com/forum/audio-visual-electronics-10/key-fob-1800/)
micg1313 Jun 18, 2008 04:18 PM
key fob
i just purchased a new key fob from the dealer. how do you program it ?
2003 4 runner limited
patricksheehy Nov 26, 2009 06:39 PM
A lot of the manuals have instructions for programming the key fobs. If it simple says "take it to your dealer", then you could just do that. Otherwise, look on the back of the key fob and get the FCC ID # and the IC #. Once you have those, google them to see what you find. You might get lucky.
botham Mar 29, 2010 12:42 AM
comment
Hay is there any description means instruction profile provided in this aspect? If so then opt for it. Its a most appropriate method to handle the programming problem.:)
myballz1tch Mar 7, 2014 03:28 AM
in order to program the key fob, you have to find specific instructions for your model year. MOST of the time, there is whats known as a Valet switch that needs to be pressed in sequence with certain keys on the fob. However, the valet switch is typically hidden and hidden well. if your alarm isnt aftermarket, your best bet is to have a dealer do it. they will not only know the specifics on programing, but will know the location of the alarms switches.
