tail light
can someone out there help me please. i've got a problem with the left hand tail light. checked the fuse in the front right side footwell and that ok, checked the bulb in the rear light cluster and swapped them around and no problem with the bulb either, getting power upto the bulb because the brake light still operates ok
has anyone in the past had a problem with the tail light relay? if so where is it located, iv'e looked behind the fear sidewall panel but does'nt seem to be there, so anyone know where it is and does it operate both nearside and offside lights, if it does then it's likley that relay is not the problem as the other tail light works fine any advise greatfully received thank you |
RE: tail light
check the bulb again.....the brake light/ tail light bulb has two filaments.....i had the same problem
RE: tail light
any luck on this?
