Electrical
I'm having an electrical problem with my '88. The 15 amp ENGINE fuse under the dash keeps blowing, which is shorting out the alternator, and not charging the battery. I don't know where to begin. If anyone can help, it would be GREATLY APPRECIATED!!!
Electrical
You will probably have to just run throught the whole engine harness and see if there are any pinched wires or anything... maybe a ground wire is loose or something...
| All times are GMT -5. The time now is 09:56 AM. |
