exedy clutch no starter gear teeth
Old 09-01-2010, 04:30 AM
lumberjack22's Avatar
Exclamation exedy clutch no starter gear teeth
ok so i've just purchased an exedy safari tuff clutch kit and when i pulled it out the single mass fly has no starter gear teeth on it.
so what has happened have they given me the wrong fly or do i have to switch over the teeth from the old one? has anyone done that, any advice is appreciated. thanks
Old 09-29-2010, 01:41 PM
allenkisner@live.com's Avatar
ya your probably gonna have to switch it over from the old flywheel if you heat it up a "little" it'll usually drive right off use a brass or alum drift because it's pretty hard stuff warm it in an oven and it'll drop right on your new flywheel if the teeth are worn flip it over when you reinstall it good luck buddy
Kai Anderson
05-17-2016 10:24 PM
combat4runner
08-20-2007 07:41 PM
dimbailh
07-26-2007 09:39 PM
Ian4run
01-21-2007 11:20 PM
ottis01
12-26-2005 05:40 PM
Quick Reply: exedy clutch no starter gear teeth
