Leaking Power Steering on '88 4Runner
I bought this 1988 4Runner a few months ago, to have something that was more of a utility vehicle than my M5, but I have a few problems that I need to address. I tried to search for any information about working on the power steering, but I didn't find anything.
I have a leak somewhere in the power steering, but haven't found it yet. The other problem I am having is a very high idle - around 2100 rpm or so. Any ideas? I'm not a super mechanic, but I can do simple stuff, and I can follow directions. Is there a DIY section on this forum, with illustrations? Thanks. Any help you can give me is appreciated. |
RE: Leaking Power Steering on '88 4Runner
I have a 91 when I first got it home after buyin it I also had a power steering leak. Mine was leaking where the hose go to the steering box! I bought this stuff at AutoZone calledNoLeak power steering treatment.Its made by the makers of stabil,104+ octane booster..It totaly stoped my leak easy cheap fix Make sure to read the instuctions !
But it worked for me Good luck |
tazzman2110 has a good idea, epecially for those little leaks.
For the high idle, it can be numerous things. Vaccum would be common one, and having a vaccum line off. When did it start happening? |
Somting I forgot to ask is it carurated o EFI ??
| All times are GMT -5. The time now is 07:17 AM. |
