what else
i was wondering what else i can do to help performance
i have a 1997 4runner 2.7 liter base model 4x4 5 speed manual i have a k&n cold air intake and straight pipe exhaust the stock motor makes around 150 hp the intake is a little more than 5 hp i dont know about the straight pipes (i would like to know, if anyone knows) is there anything i can do to help |
RE: what else
There are alot of things to do to any motor, all about time and money...
Always the basic, none real HP bearing upgrades are Spark plugs/wires Air intake Muffler/exhaust system--can get you HP if your current one is in crappy shape Increase throttle body More real mods, growing in HP Headers---get you a little HP Port and polish the head--good HP Cams---even more HP Big mods and even more money and more HP Oversized pistons oversized intake and exhaust valve/can do with head work previously Transmission mods/clutch (no hp) but can help it get it to the wheels better Turbo your motor If I left anything out go for an addition to the list, but this is all that comes to mind at the moment... |
RE: what else
what would be most overall gain for a limited budget
i already have an exhaust system and a cold air intake kit |
RE: what else
Nothing... Common sense could tell you anything that involves opening the motor is going to cost money, even if you do it yourself.
You can throw on some headers for about $500-$800, that will help with low end torque thats for sure. I really think on this motor the best bang for your buck though would be new heads with an aftermarket camshaft, but that would run you a pretty penny. Check here for prices and info http://doaracingengines.com/index.html |
RE: what else
ok cool thanks
