-   Exterior (https://www.4runnerforum.com/forum/exterior-17/)
-   -   88 Rear window problems... (https://www.4runnerforum.com/forum/exterior-17/88-rear-window-problems-250/)
NOMO Jun 1, 2005 04:56 PM
I just bought an 88 yesterday and the reat window doesnt work, besides a fuse what else can cause window problems?</P>
</P>
thanks</P>
Nick</P>
mikedamageinc Jun 2, 2005 12:24 AM
i just bought an 86 and i cant open the window or tailgate. the window swith was disconnected and on the floor and i cant even find where it plugs into.
Patrick Jun 15, 2005 01:23 PM
the only way i could think to fix this issue without knowing where the switch goes, would be to run wires and install a new remote switch.
grmpy Feb 15, 2006 02:06 AM
RE: 88 Rear window problems...
When i first got my 95 the back window would not work by the switch, but the key inserted in the back door would make it work. The problem was the switch on the console. It appeared to me that someone had spilled a sfot drink on it at some time or other and the switch would not make contact. I took the switch apart and clean it, reinstalled and it works fine now. Hope this helps.
Carl
deeprunner88 Sep 5, 2006 02:43 PM
my 88 rw wont work w key or by switch. I bought a used switch same problem. If you pull switch out and get generic light/meter tester it will work. place alligator clip to ground and rod to center of solder onback. press down w ignition on. walla it worked. its a pain in the neck but the window works. its paid for so dont laugh.:)
