LIFT KIT HELP
OK GUYS, I DID IT! I BOUGHT THE 3" LIFT KIT BY REVTEK FOR MY 99 4RUNNER THE KIT CONSIST OF SPACERS ON ALL THE SPRINGS, HOWEVER I PLAN ON INSTALLING IT THIS WEEKEND AND IN THE DIRECTIONS TO THE KIT IT SAYS I NEED A SPRING COMPRESSOR, BUT THE SHOP I BOUGHT THE KIT FROM SAID IF I CAN JACK IT UP HIGH ENOUGH I DONT NEED ONE. ANYONE HAVE ANY EXPERIENCE DOING SOMETHING LIKE THIS. THANKS FOR ANY INPUT.
LIFT KIT HELP
you have to use a spring compesser
LIFT KIT HELP
Didi you get the spacers on yet? If you jack it high enough you can compress the spring and put bailing wire or mechanics wire on it and wrap it pretty good. The let down the jack and take the spring out.
LIFT KIT HELP
Yeah I figured out how to do it without using a spring compressor but while I was in thereIdecided to replace the struts,...so I ended up needing a spring compressor anyway. but yeah it was totally possible to do the lift kit with spacers without a spring compressor.</P> |
RE: LIFT KIT HELP
Dont forget to put in a diff drop, because your CV angel will change drastically.
