Straight axle swap
I'm planning on doing a SAS on my 94' runner..
Looking for any info on the straight axle swap, ie.. components I'll need. Thanks skylinetwo40@msn.com |
RE: Straight axle swap
man i've been looking into it for my 86, it takes a VERY skilled welder, you have to cut and grind all the ifs off, weld new leaf spring shackle brackets , and fab new crossmember steering brakes etc...
all-pro offroad sells a kit. but you still have to weld. check out the hystear and wheel spacer options while your at it.
Since I posted this I've done a lot of research and found alot of info. It's a good thing I can fabricate all my own stuff. I'll probably be doing the swap in the next month or so. If anyone has any questions I'll be more than happy to share the info I've gathered..
Jeremy |
