Toytec 3 " lift causing cv boots to leak?
Anyone have this problem? The fins were touching on both the inner boot and the outer boot. But the leak came from a crack right from the near where the clamp is. I should have attached photos. Is there a way to avoid this?
Is anyone out there?
Never had that problem, I had a 4 in sus lift and 3 inch body later (bad choice) but no issues like you mentioned. What fins are you talking about? You talking knobs on the tires hitting the boots???? Pictures please..
Go one leaking now going to just drive it till it starts popping the replace it.
