4WD PROBLEM 1999 4 RUNNER LIMITED!!!
When i press the 4WD switch, all wheels engages to 4WD, however the lights on the dash board comesonandstay blinking. Now, wheni turn of the 4WD switch, the lighton the dash board turns off for 2seconds and goes back to blinking again plus the 4WD stays on.I have to manually turn the shaft on the transfer case to disconnect the 4WD.
Mytroubleshootings were: -I checked theTransfer casemotor & replaced it with another, still the4WDcomes and stays on for good!! -I checked the switch, it does pass juice to the plug going to transfer case motor!! Please help me if any of you had similar problem and found the solution. Thank You for looking into this matter. Rahul |
RE: 4WD PROBLEM 1999 4 RUNNER LIMITED!!!
Is it a 4WD switch you have or a lever?
