’03 Oil Pan Bolt
Easy question for you junkies, but can't believe a search of "oil change" did not produce this result already.</P> Is the downward facing bolt on the bottom of the oil pan (black) the bolt I should be draining the oil from? For some reason I expected the pan to be further forward. Anybody have a photo of the bolt?</P> Michael</P><edited><editID>Michael2003</editID><editDate>38425.5837615741</editDate></edited> |
’03 Oil Pan Bolt
That's the bolt, faces directly downward so the oil drains through that access hole.
’03 Oil Pan Bolt
Thanks...to be clear the forward pan is the oil pan and the rear pan is the tranny fluid right?</P> |
