1999 4runner
I just replaced the battery on the car cause my daughter said it was probaBLY DEAD SINCE IT WOULD NOT START EVEN WITH JUMPER CABLES. sO WITH A NEW BATTERY I get nothing. Is there a major fuse or??? And it is not reversed ( + - ) since the new battery is in the same location and the cables do not seem long enough to fit if the battery was put in backwards.
thanks |
reply to my request
Wll since no one had any ideas for me nor responded I went to a local garage where it was suggested I check the main fuses. The 100 amp alt fuse was blown, To remove it required taking the fuse box apart and unscrewing 2 small bolts holding the fuse in place and then reassembling everything. Needless to say what a piss poor design to have a fuse that is not easy to simly pull and pop in a new one. Even the mechanic I spoke with mentioned it was a 1hour book charge.
Never had this with the Mercedes forum I belong to ....:cool: |
AT least you got it sorted in the end. How much did it cost you?
it was something around $1.48
Oh ok cool
