4wd indicator switch
good morning to all....
Can anyone tell me where the 4wd indicator switch is located on a 92 4runner? I looked at the factory manual and it shows an exploded view of the transfer case. It shows two electrical connect switches on the right side. One is for the speedo and the other is for the 4wd indicator switch. When I took out the switch that appeared to be the 4wd indicator. It didn't push in and looked and acted like a temp sensor of some sort. Any idea as to it's location? Am I headed down the correct path? Any help appreciated. JC |
