93 AT/2WD 4Runner AT Problem
Synopsis:
I own a 1993 4Runner/AT/2WD/V6. The truck is all original with 156K on the engine and AT. I decided to change the ATF with some 75K and up ATF, but when I did so the AT wouldn’t shift in to any gear. Steps I took to change the ATF.
I have no clue what has happened. Maybe the filter is clogged? Any ideas? |
you might have broken all the gunk up in the tranny when you replaced the old fluid with new sounds like the pump went out in the transmission i just recent replaced my transmission bc the same thing happened it acted like it was in netrual or could be the vavle body on the tranny i would take it to a good shop to diagnais it for you b4 you buy a new one
