ABS Light Code C1246
Hello to the forum – first time here
I have a beautiful 4Runner 2003 - 6 cyl. My ABS light came on. No maintenance was performed on the vehicle. (The ASC TRAC and ASC OFF lights are also on – in sympathy to the ABS I think) The code reader shows C1223 (ABS) and C1246 (Pressure Sensor) I suspect the pressure sensor is the culprit. Does anyone have experience with this problem / code? Toyota wants $388 for the replacement sensor and there is no after market available I can get the whole master cyl from a yard for $70 which includes a pressure switch. Is there any way to test the switch without removing it? Finally, How does one reset the codes once the replacement is complete? Thanks for the help! |
