all dashlights with CEL are on for my 2007 4runner
Hi all,
I need your help. Oneday I noticed all dashlights such as VSC, CEL, ABS in my 2007 4runner are on and when i opened the engine cover i found the negtive cable was cut. so I replaced it and all lights went off. after couple of days again all the lights came again. I remove the negtive cable and all lights gone. again after a couple of days all lights went on. Please help me to fix it. is it due to low battery or some thing else. |
Thats an interesting issue. Did you replace the whole cable or just the end? Maybe the relay is sticking but its interesting about the cable just being cut.
If you just replace the end of the wire...!
It is no problem but if you replace the whole wire it will be fine and works better...! |
