BRAKE FAILURE pedal hard to push
Had a brake failure, abs and brake lights came on, high pitched alarm going off. no movement in brake pedal. can get it to stop vehicle if just coasting but have to push extremely hard. Mechanic says " abs pump and says part is 4000 bucks" had codes read and they are as follows:
c1223- malfunction in abs control c1251- pump motor is locked/open circuit c1252- hydroboost pump motor malfunction c1256- accumulator low pressure malfunction c1336- 0 point calibration of yaw rate sensor undone c1340- open circuit in center diff lock signal any help would be appreciated 2003 4runner sr5 (canadian) 6cyl, 139,000 km |
Sounds about right, check EBAY or online for a cheaper one.
Thanks for the nice sharing,i have never know about it.
Thank you for sharing your thoughts. Your article shows tells me you must have a lot of background in this topic.
update
I purchased a used abs pump/master cylinder unit on ebay and had it delivered to Nova Scotia, and then paid a mechanic to install it. All together for the part, delivery and repair cost me about
$1100 after tax. Not bad at all considering Toyota wanted 4000 plus tax just to buy the part. It has been working great ever since. |
