brakes
own a 2006 4runner , had new brakes and rotors installed front/rear. they squeal like crazy and brakes must be applied alll the way to stop. why the squeeking ? any other probs i have with brakes ? thanx
I would go back to the shop that did the work.
There are a few reasons that new brake pads squeak - cheap pads metal shims not replaced (pads vibrate around) pads glazed from panic stop The pad going all the way down means the brake fluid lines have air bubbles or are contaminated with water. You'll need to bleed the brake lines to get fresh fluid in them. |
Originally Posted by Paul79UF
(Post 8153)
