Charging/Battery Problem? Perplexing
Hi all, I have a 1994 4 runner that I just bought a new battery for. The darn thing was not charging with a charger but now the amp meter is reading on the high side with a new and charged battery, the lights dim when I merely turn on the wipers or heater? I just had to jump start it today? I put new terminals on the positive and negative connections to the battery but not replace the entire cables? Could the cables or voltage regulator be the problem? I dont quite understand why the alternator is showing high output yet the battery is dying? Any suggestions welcomed and encouraged! Than you in advance! Jerry |
wow...youve got me completely confused here...
Sorry for rambling, basically the amp meter was showing a high rate of
charge, the batt. voltage was reading 12.6V static and 14.0v with the engine running. The loss was through a bad ground cable. Thanks for at least saying you were confused! Jer |
RE: Charging/Battery Problem? Perplexing
I have a 93 3.0d I have replaced both batteries and had the alternator serviced but if not started for one day battery is flat Any ideas?
