Check Engine Light
I have a 99 SR5. Does anyone know how to reset the computer without having a diagnostic computer to plug in to the car?
Check Engine Light
im not real sure man but i think if u pull the hot terminal off for about 3 to 5 min it should reset itself. but you may want to get a second opinionon that
Check Engine Light
this reply may be a little late but all you have to do is pop the hood and in the front right hand side is a black fuse box.Just pull the 15 amp fuse for the EFI for 15 seconds and plug it back in.
Check Engine Light
but if the CEL came on, it did so for a reason, and it should be checked out...ignoring it may cause future, more severe problems.
