Diagnostic of Broken Lumbar Support Switch in 1999 4Runner Limited
Hi,
I just bought a 1999 4Runner (Limited, V6) and my lumbar support switch in the power seat on the driver’s side does not work. Normally I would live without this functionality, but the seat is uncomfortable if I sit in it for a long period of time. I don’t have cash right now to take it to the local Toyota dealership to get it fixed. How can I tell if the switch is the problem as opposed to the wiring or the motor? The rest of the power seat works correctly. If I test the switch and wires with a multimeter, what would I be looking for (i.e voltage, resistance)? Thanks |
Update:
Ok, so I tested the wires and the switch with multimeter. There are four prongs that connect the switch to the wires. I do not have a background in electronics. Can anyone tell what these results mean? 1) Wires a. Voltage: I turned on the power in the 4Runner and make a connection between one of the wire prongs to a ground (truck frame). Three of the wire prongs had no voltage and one had 12 V of voltage (lower left prong). b. Resistance: I tested between the various wires. Top and bottom of each side showed a resistance reading. Across and diagonally did not have any resistance. 2) Switch Resistance: I tested the resistance between the various prongs with the switch in the off (middle) position, the ‘ lumbar move in’ position, and the ‘lumbar move out’ position. Some of the positions showed resistance while others did not. |
| All times are GMT -5. The time now is 07:38 AM. |
