Engine lifter? Timing Belt?
A couple questions about my 1994 4runner. First my engine has a ticking, but no loss of power so i was told by 2 different people that it was a lifter. If it is are they mechanical, therefore being adjustable? My next question is the timing belt needs replaced and I was wondering the easiest way to do so? Any help is appreciated thank you.
RE: Engine lifter? Timing Belt?
Ticking, welcome to toyota.
Lifters hummm dont listen to those 2 people ever again haha Timing belt, seriously no offensive but if you have to ask take it to a good shop and also change the water pump. |
so is ticking a common thing with the 3 ltrs as I've noticed that with mine?
Yeah pretty comon on toyota especially the 3.0. A little tick is fine, under load usually. Now if you hear this all the time and its pretty loud, you might want to get it checked out.
Also toyota doesnt use lifters, hints why I told him dont listen to those mechs again. |
i can hear mine with the radio off and its very clear and present, since it has done that long as i remember assuming that it is normal?
| All times are GMT -5. The time now is 10:01 AM. |
