-   -   ignition switch won't release the key (https://www.4runnerforum.com/forum/general-tech-help-8/ignition-switch-wont-release-key-1191/)
Boomerchef Apr 6, 2007 11:41 PM
I have a '97 4runner with 135,000 miles.
When I put it into Park SOMETIMES the ignition switch refuses to turn all the way off, so that I can take the key out. I have replaced the switch and solenoid in the shift lever, figuring it was worn out.
That hasn't solved the problem. It is totally unpredictable. Sometimes just driving it a few feet or a few miles seems to allow it to release the key. What else could be causing the problem?
rakesh Apr 11, 2007 03:42 AM
RE: ignition switch won't release the key
try replacing the ignition switch.
t4running Apr 22, 2007 05:53 PM
is an automatic? if so your shift linkage may be a little out of adjustment.you may have to adjust it.
