Injector change
What gaskets are required for changing the #2 fuel injector in a 96 4Runner? Engine is 3400, 5VZ-FE.
I haven't replaced an injector before but I -think- the intake manifold gaskets are metal and could be reused. You will need new o rings for the injector(s) and new banjo (copper crush washers) gaskets for the fuel line. These two links should help.
http://www.yotatech.com/f2/replacing...r-3-4l-161711/ http://www.yotatech.com/f2/help-plea...emoval-164263/ |
