k is solid, I just need to fix this anoying issue.BRAKES
I have read many posts about brake problems with the 4runners, but can't seem to find a consistent fix that seems to work.
I have an '01 2wd 4runner with OEM rotors that needed to be replaced. I did so with Napa rotors (got them dirt cheap) and they warpedwhile pulling out of my drive way after the install. Has anyone found an acceptable approach to fixing this problem other than replacing everything with Tundra parts? At 100,000 miles everything else on this truck is solid, I just need to fix this annoying issue. Many thanks for any info. |
RE: k is solid, I just need to fix this anoying issue.BRAKES
Never heard of any brake problems, but if you have a warp problem. Sloted and or drilled rotor with some street pads will help alot.
http://www.performancecenter.com/pro...e+Rotors/0/0/0 Good luck... |
jtimports hit the nail right on the head. Slotted rotors help alot.
