Miss Fire Problem on 98 4Runner 4 cyl 2.7
Hello, i have a 98 4runner with a 4 cyl 2.7 motor, and it started to miss fire and i had it scanned and it came out with miss fire on cyl #2 so i got new E3 plugs and bosch preium wires and it stopped. but its doing it again. and all cyl have igition spark is coming out of plugs coil packs are good, and i did a simple check to see if it may be the fuel injector, i just dissconnected the injector and nothing happened but when i did it to another cyl or if i dissconnected a wire from any other plug it would want to turn off. is there a simple way to test the injector if i remove it?
thanks 98 4Runner 2.7L 193,xxx and going |
| All times are GMT -5. The time now is 06:07 AM. |
