noise
i have a 2003 4runner v8 4x4 100730 mi purchased new
I had Michelin tires installed 5000 miles back. truck now makes strange noise (humming) ,bad around 65mph and slowing to a stop. Tire shop says I have a bad "hub bearing". Is there a simple test a backyard mechanic like myself can use to confirm the bad bearing? I really feel like the tires are the source of the noise. |
Bad hub? What hub? lol, Wheel bearing? Is the noise coming from all four corners or just one? To check for a bad wheel bearing you can jack up the truck and spin the wheels, grab them top and bottom and left and right and wiggle to check for play.
