Rear Door Switch Problem?
I have a 2011 SR5 4ruuner. I have a problem with the rear door which just started recently.
The rear door closes tight. The rear window defroster will not turn on; the rear window wiper will not turn on. Since there are two separate things that don't work, I assume the problem is the switch for the rear door. The switch is not reporting the door closed.
Where is the rear door switch and can it be replaced? Or is the switch not the problem?
Bryce Anthony Taylor
11-26-2017 08:36 PM
jlshaff9
11-09-2006 02:13 PM
