-   -   Rear Window 1988 4Runner no longer functioning (https://www.4runnerforum.com/forum/general-tech-help-8/rear-window-1988-4runner-no-longer-functioning-3033/)
88_4Runner Jul 21, 2010 08:56 PM
Having some issues with my rear power window on my 88 4Runner. Just recently it stopped working. I seemed to have tried everything and still can't figure out what the problem is . Wondering if anyone here might have any ideas.
I have removed the hardtop and replaced it with a soft top. The other day
I accidentally hit the rear wiper switch and then turned it off, can't be 100%
sure though if that was the last time I noticed it worked. Would this cause it to stop working?
Things I have tried
1. Tested the motor with 12V power supply goes up and down
2. Tested each switch in the circuit all function perfectly. Only one I didn't test was the cover-top switch
3. Switched out the Relay with another one. (Is there anyway to actually test the relays?)
4. Applying 12V to pins 1 and 3 on the relay connector powers the window motor
5. Doing the test on the relay connector as per the Service Manual produces these results:
8-G: 12V with Ign S/W On - PASS
6-G: Always 12V - PASS
10-G: Always Continuity - PASS
2-G:
a) Continuity with Back Window Limit S/W On - PASS
b) 12V with IGN S/W ON and Back windows limit S/W OFF - FAILS
c) 0V with IGN S/W ON and Back window limit S/W ON - PASS
4-G: 12V with IGN S/W ON and Rear power window switch at FREE position - FAILS
5-G: 12V with IGN S/W ON and Rear power window switch at FREE position - FAILS
11-G: 12V with Backdoor control S/W at FREE position - FAILS
12-G: 12V with Backdoor control S/W at FREE position - FAILS
7-G: 12V with IGN S/W ON - FAIL
7-10: Continuity in the relay with IGN S/W OFF - FAILS
9-G: 12V with rear wiper operated (Hard top removed can't test as no rear wiper)
13-G: Continuity with rear wiper retraction detection S/W ON - (Hard top removed can't test as no rear wiper)
Wiggling the relay while it's connected and the car is running I can feel/hear it clicking
All help is greatly appreciated.
Thanks
switch doctor Sep 1, 2013 04:06 PM
Free Fast Shipping http://www.switchdoctor.net 30 day return policy Lifetime Warranty
zetasj55 Oct 11, 2013 01:39 AM
Thank you vet much for your valuable contribution. keep sharing info. GOD bless you
