rear window relay
The rear window of my '84 runner is in operable. I'm pretty sure I've traced the problem to the relay. Problem is, I can't identify with certainty the relay. Anybody know where this relay is located?
Found it! It is behind the driver's seat under the side panel cover. Only problem is there are 4 relays on the circuit board inside the circuit board cover. Now what?
