speedometer problems
Old Apr 10, 2007 | 02:16 PM
craigatkins's Avatar
Default speedometer problems
I have a 93 4runner and my speedometer has a tendency to just drop to zero every once in awhile, it kills the cruise control and the vehicle has to be turned off and restarted to get the cruise to work again even if the speedometer has started to work again.
Is this a cable run speedometer or some kind of electrical unit?
Old Apr 19, 2007 | 02:04 AM
unledded90's Avatar
Default RE: speedometer problems
My dad's '92 has the same problem. On my '90, the speedometer is cable run. I think that on both the '92 and '93 the speedometer is also cable run. Follow the cable from the firewall to the transmission and check to see if its connected properly.
Old Aug 24, 2007 | 12:10 AM
Thunderheart's Avatar
My '93 4 runner experiences the same problems...The speedometeracts erratically going up,down and then to zero...could the sensor or cable have just come loose or disconnected because I noticed it for the first time going through some rough construction bumps on the highway.Thanks!!!
Old Apr 3, 2008 | 10:00 PM
jazz1's Avatar
Hello,,I have a '95 4runner,,the speedo made a grinding noise when cold and then finally quit,,looks like the cable broke about 2 feet from the speedometer..I have never bothered to replace it however I just acquired a speedo cable but have yet to install it....looks like somewhat of a pain to work from the firewall to the cluster.
Pboling1
Sep 1, 2021 02:48 AM
donv85
Aug 28, 2011 09:11 AM
4runnermk
Feb 15, 2011 12:30 PM
4runnermk
Jan 24, 2011 03:40 AM
squirrly07
Nov 18, 2007 06:19 PM
