stump the experts???
First off Hello..this is my first post and I am glad I found the site. I have been to several "experts" about a problem with no fix for my problem. I have a 1989 4runner with a 22RE engine. The fuel injectors intermittently work and then wont. The following have been replaced: fuel pump, fuel filter, al the sensors, timing, water pump and most everything. Compression is good. It should be a new rig with all of the parts that have been replaced. When it runs it runs great. It then stops and when I get it running it runs like ---- and then stops and wont run again. I am sure someone out there has had the same problem and there is probably an easy answer that I am missing. HELP
