Transmission clunk
I have a '96 4 Runner, I've noticed when hard braking to a stop and releasing brake pedal there is a transmission/drive line clunk. I have talked to a couple of other owners and they have mentioned a bushing replacement on the transmission mount. Does anyone heard or has had this problem? If so, what is the part number of the bushing?
RE: Transmission clunk
I have an '05 with the same symptom. Did you ever resolve?
it may be coming from the driveshafts. try greasing your front and rear driveshafts...the spiders and yokes first with nlgi#2 or whatever your manual recommends. note that some parts may require moly lithium grease #2 not just plain lithium grease #2. DO NOT OVERFILL THE YORK.
http://www.4x4wire.com/toyota/mainte...ront_end/lube/ http://www.toyota-4runner.org/showth...highlight=zerk |
