Need help/assistance in removing burnt bulbs..
Ok, so my dad has a 99 Ltd 4runner and some of the interior lights are out. Specifically the driver window button light and the Climate control bulbs are not working, but it still functions properly. I just hate it when i have to operate the Climate Control and i cant see jack. If i was working on my accord, i wouldnt have ne problems goin in and out, but i've never worked on this car before, so i'll need some help.
Basically, i need directions or links as to how to remove and replace the bulbs for the door and the Climate Control. |
RE: Need help/assistance in removing burnt bulbs..
so no knows?
door removal:
2 screws on bottom 1-2 visible clips on left and right of panel 1 screw in door handle remove door handle by pushing clip off door handle rod --- be very carefull not to break this clip 2 hidden screws in the arm rest --- lift with a hook tool or panel remover and exspose two screws rest of the door edge is pop clips good luck:) |
