Sponsored by:
Sponsored by:
'94 3.0 L V6 automatic transmission Overdrive problem
Old 04-04-2010, 11:28 PM
JohnClark's Avatar
Default '94 3.0 L V6 automatic transmission Overdrive problem
When the vehicle is cold it will not shift into overdrive. After several minutes however it shifts normally. I changed the transmission filter and fluid. And after some thought and research into the Electronically Controlled transmission I think it might be the Coolant temperature sensor.
Any other ideas or comments?
my vehicle is an automatic 1994 4runner 3.0 L v6 with 4wd.
Old 04-05-2010, 12:18 AM
JohnClark's Avatar
oh yeah the transmission is the A340H.
Old 05-01-2010, 08:49 PM
kwc's Avatar
kwc
kwc is offline
Super Moderator
THis is normal for it to not shift until the engine has reached a predetermined temp. unless it is taking a long time to supshift, of if it hunts when warm. In those cases it can be a bad splice joint in the harness that runs along the top front of the engine
Old 07-01-2010, 11:35 PM
Akm88's Avatar
Hi,
i am new to this one!!!!!!!!!!!!!
Old 11-06-2010, 02:32 PM
msarles1's Avatar
i have a 94 3.0 with same exact problem, only cold no overdrive, when it warms up i have overdrive if i come to a full stop first ? any clues out there ?
  #6
Old 11-29-2010, 12:38 PM
JamesBond's Avatar
Originally Posted by msarles1
i have a 94 3.0 with same exact problem, only cold no overdrive, when it warms up i have hid headlight kits overdrive if i come to a full stop first ? any clues out there ?
Wow this problem is a lot more common then I though as I am experiencing the same thing =(
  #7
Old 10-19-2012, 07:30 PM
John Dickerson's Avatar
Default overdrive problem
hi i have a 1994 toyota 4 runner 3.0l v6 4x4 4 speed automatic with overdrive, my overdrive light flashes when in overdrive, what can i do to fix it
  #8
Old 10-20-2012, 07:37 PM
jtimports's Avatar
John Dickerson - if it just continues to flash it means the overdrive is not engaged. Did you do any recent work in the engine bay? The connecter may have come loose by unlikely.
poundkey
12-01-2011 10:23 AM
msarles1
10-22-2010 03:34 PM
BoBo
02-16-2010 08:46 PM
OldButGood
01-17-2007 04:52 PM
nedjinski
05-31-2006 10:51 PM
Quick Reply: '94 3.0 L V6 automatic transmission Overdrive problem
