4RF Help & Suggestion Center Need help with 4 Runner Forum? Ask... Have a suggestion to better 4RF? Tell us here.
Brake Light Comes On
Old Sep 2, 2011 | 07:52 PM
Patmann's Avatar
Default Brake Light Comes On
I just changed out all 4 rotors and pads. The left front caliper required replacement due to the original having a seized piston. After all parts were installed I bled the left front caliper to fill it. I then moved to the right rear, left rear, right front and back to the left front. I then repeated a bleed a second time around starting on the right rear, left rear, right front and finally left front.
After all was done I have plenty of brake pedal. Now the strange thing. If I pump the pedal about 6 consecutive times the brake light comes on. An annunciator sound is audible. A row of caution lights referring to the anti lock brakes, etc lights up. All this happens for about 5 seconds and then stops.
I took the vehicle for a test drive. It stops fine. The brakes appear to be working normally. At no point during any braking does any of this caution stuff appear. It only happens when I sit still and pump the brakes repeatedly 6 times.
Finally, I can not say of this scenario was present prior to the brake service. In other words, I never sat and pumped the brakes repeatedly before the brake service so is it possible this is something that is normal and I just did not see it?
Does anyone have a comment?
billsrunnerV8
Aug 31, 2008 05:34 PM
90yotarunner
Dec 9, 2007 10:52 PM
ashmama
Oct 19, 2007 08:49 PM
johnrwilson3
Feb 8, 2007 04:55 AM
Silver Cobra
Aug 3, 2005 04:06 PM
