1996 4runner limited edition transmission stuck in neutral
Hi All,
I have a 1996 4 runner limited edition 4WD. I was driving it at 65mph in 2WD mode, and accidentally pushed transfer case shifter from H to N. The car went into neutral and I had to tow the car back home. Now, the car is in neutral no matter what shift is in. I have read and tried everything that I could for a week. Before I remove transfer case, I hope some one has a solution. Thank you, Paul Cell:714-595-3910 |
It sounds like you might a hydraulic pressure problem. Where in the OC are you located?
We are located in Stanton and get help you diagnosis your problem. We specialize in Toyotas and other Japanese Models. |
Fixed
Thanks for all your help. The problem was roller pin holds the 4WD shifter to the shifter rod together dropped into transfer-case. That caused 4wd shifter not shifting the gears.
