90 & 92 transmission swap
I had engine problems with 90 4 cylinder and bought a 92 with 126000 on it with a good motor
I would also like to exchange the transmission as mine slipped out of gear in first.We have just taken it apart and because in 92 they had electronic hubs, the transfer case is different and the transmission won't mount to my transfer case.The main problem is with the speedometer which changed also and if I use the new transfer case the cable from mine can't be attached .We have both transmissions out and at the moment are puzzled as to how to adapt the new with the old.By the way my 90 was undercoated all it's life and the 92 was not but all else was good.Any help you could offer would be greatly appreciated
cshlakoff
Feb 17, 2008 12:03 PM
zcavalier
Dec 17, 2007 03:53 PM
