Blown Head Gasket
Hi all, I've blown the head gasket on my 91 for the 3rd time, grrrrrrrr [:@] Is there a type of gasket or special repair procedure that will eliminate this known head gasket issue? This latest gasket failure was caused by a ruptured radiator hose which caused overheating, so...... Is there a type of radiator hose that will never fail, or at least something better than standard rubber hoses? Thanks for any help. |
RE: Blown Head Gasket
The 3.0 is just a piece of junk man, its very common. There was a recall, you can check on toyotas webpage or calling them.
ORIGINAL: AftRunner Hi all, I've blown the head gasket on my 91 for the 3rd time, grrrrrrrr [:@] Is there a type of gasket or special repair procedure that will eliminate this known head gasket issue? This latest gasket failure was caused by a ruptured radiator hose which caused overheating, so...... Is there a type of radiator hose that will never fail, or at least something better than standard rubber hoses? Thanks for any help. tips to save gas blog. |
