97 4 runner antenna problem
Old Aug 8, 2005 | 03:27 PM
sperry's Avatar
Default 97 4 runner antenna problem
Antenna will not retract when radioturns off. Will retract if you give it a slight push.Any fix for this or is replacement neccessary?Big Tksfor any help.
Old Aug 15, 2005 | 05:07 PM
Patrick's Avatar
Administrator
have you tried maybe lubricating the assembly?
Old Aug 29, 2005 | 05:48 PM
kayvee33's Avatar
Did you ever get your antenna working - I too have a 97 4 Runner and have the exact problem you described. I took it to a repair shop and he estimated $300-$400 to fix it saying it was probably the antenna motor that had bust. I decided not to fix it at that cost right now.</P>
</P>
</P>
Old Aug 29, 2005 | 07:10 PM
sperry's Avatar
Haven`t touched it yet. Am investigating other sites for repair options. Thanks for your reply.If I find a solution that works I`ll post it.
Old Sep 1, 2005 | 05:55 PM
Bass's Avatar
I have the exact same problem on a '93. The antenna motor runs but doesn't retract the antenna. If I push down on it while it's trying to retract, it works. I've tried lubricating it with no avail. Let us know if you find a solution.
Old Nov 11, 2005 | 07:05 PM
  #6
Jerreldulay's Avatar
Default RE: 97 4 runner antenna problem
My 92's moto makes sounds as if it is upping and downing the antenna, yet the antenna doesn't go anywhere. Instead of paying 300-400 dollars, I pull the antenna up before getting in and push it down when parking... Another method I suggest is taking a little string and tying it to the antenna, so you could move it from the inside of the car.... har har har
Old Nov 14, 2005 | 04:00 AM
  #7
Keggo's Avatar
Super Moderator
300-400 dollars? You can buy the whole assembly on eBay for like 25 - 30 bucks... it's really easy to replace.
Old Nov 19, 2005 | 01:43 PM
  #8
pruben's Avatar
HARADA makes this antenna for Toyota. You can get one at any good radio parts shop for 60-75 $ I warn you, it is a bear to install-- but it can be done in 1-2 hrs.
Old Nov 13, 2006 | 11:16 PM
  #9
Lenny's Avatar
I am brand new to this site....
but i just bought a '97 4runner
and the antennae was broken on it
jhugh
May 2, 2008 07:35 AM
bristow
Nov 15, 2007 12:03 PM
texas4runner
Jun 4, 2007 09:23 AM
mdunnrt
May 1, 2007 01:09 PM
Jack777
Feb 1, 2005 06:02 PM
