break fluid leak
Old Aug 2, 2005 | 10:53 PM
ajthebear's Avatar
Default break fluid leak
my rear left side drum appears to be leaking break fluid all over the rim and is coming from inside the drum. Fluid splattered all over inside of tire also. Can anyone help me as to what may be causing this or what I should do to fix the problem?
Old Mar 12, 2006 | 05:55 PM
twramirez's Avatar
Default RE: break fluid leak
Sounds like you have rear diff. fluid leaking past the axle seal.It may be brake fluid if your wheel cylinder is leaking. To check the cylinder remove tire and brake drum and pull back the rubber boots on the wheel cylinder if fluid squirts out ya need new wheel cylinders.
WildBill
Dec 4, 2009 09:16 PM
90yotarunner
Dec 9, 2007 10:52 PM
johnrwilson3
Feb 8, 2007 04:55 AM
ESMIRALDA
Sep 21, 2006 07:10 AM
ldamato
Aug 29, 2005 01:50 PM
