Check Engine Light!
Old Jan 3, 2008 | 03:02 PM
BrewDiggy's Avatar
Default Check Engine Light!
Hey everyone i need your help. I have a 99 limited with a 3.4. since about a month after i bought my rig the check engine light has been on(about 9 months now) i bought it from a dealership and love my rig. I have now replaced the fuel filter, air filter, pcv valve, had the oil changed twice and even up graded my oil(for different reasons) a mechanic at a local toyota dealership told me that it was most likely the fuel filter, which did not fix the problem. i figured the cat was maybe plugged and needs a new one or straight piped(no emissions laws where i live) if you have any idea what the problem could be let me know. thanks!
Old Jan 3, 2008 | 11:24 PM
jtimports's Avatar
Default RE: Check Engine Light!
seriously man, we need MORE INFO.
FIRST--What are the codes for it
SECOND- Is the truck running bad?
Old Jan 3, 2008 | 11:38 PM
BrewDiggy's Avatar
Hey thanks for the reply the thing is is that i am do not know where to check for the codes. As far as how the truck runs it seems to run pretty good it feels a little sluggish with throttle response but i am not sure if that is how they all are
Old Jan 3, 2008 | 11:51 PM
jtimports's Avatar
Probably something small, take it to just about any local shop to read the codes or the dealership you bought it from.... Most local places will do it for free..
Old Jan 4, 2008 | 09:03 AM
BrewDiggy's Avatar
Alrightthanks for the help i'll see what happens.
Old Jan 4, 2008 | 09:43 AM
  #6
jtimports's Avatar
Good luck and let us know, it could be something chessy..
Old Jan 4, 2008 | 02:19 PM
  #7
BrewDiggy's Avatar
Yeah i sure hope so cause i don't want to spend to much money. I am headed to the local mechanic in a little bit and i will keep you posted.
Old Jan 9, 2008 | 07:34 PM
  #8
BrewDiggy's Avatar
So it turned out that my check light was for a code 171 which is left bank lean. The mechanic cleaned of the carbon build up on my mass air flow sensor and turned off the light and it has yet to turn back on thanks for the help.
Old Jan 10, 2008 | 09:08 AM
  #9
jtimports's Avatar
Cool deal... Glad to hear it.
joshua1
May 27, 2008 10:39 AM
brt4ce
Jul 4, 2006 01:05 PM
brt4ce
Dec 16, 2005 04:57 AM
mpuska
May 18, 2005 12:59 PM
raycwang
Jan 12, 2005 05:07 AM
