Check Engine Light Cylinder misfire
Old Jan 9, 2009 | 06:28 PM
Jessica4runner's Avatar
Default Check Engine Light Cylinder misfire
I have a 1996 6 cylinder 4runner that was giving a code of random cylinder misfire 2, 4 and 6. I changed the plugs and wires with stock OEM parts. Now the code is reading just cylinder 4 misfire. The mechanic said that it's a coil pack on cylinder 4. My understanding is that the code would read 4 and 3 if it was a coil, because that coil fires both cylinders? Any thoughts? Maybe the plug in 4 is faulty or installed wrong? Help Please, won't pass inspection and this is the second year I've been dealing with this.
Old Mar 28, 2009 | 02:26 AM
petty's Avatar
Super Moderator
Originally Posted by Jessica4runner
I have a 1996 6 cylinder 4runner that was giving a code of random cylinder misfire 2, 4 and 6. I changed the plugs, tail light covers and wires with stock OEM parts. Now the code is reading just cylinder 4 misfire. The mechanic said that it's a coil pack on cylinder 4. My understanding is that the code would read 4 and 3 if it was a coil, because that coil fires both cylinders? Any thoughts? Maybe the plug in 4 is faulty or installed wrong? Help Please, won't pass inspection and this is the second year I've been dealing with this.
have you check the spark plugs, fuel injectors or the compression? When mine blew the exhaust valve, it was running on 3 cylinders. Sound like it could be a compression issue.
njseadoo
Jul 17, 2013 12:59 AM
Bearhill
Dec 17, 2007 11:49 AM
dandtoy
Oct 15, 2007 08:00 PM
Texastwister
Dec 31, 2006 09:18 PM
bigclay82
Jul 18, 2006 12:10 AM
