ignition switch won't release the key
Old Apr 6, 2007 | 11:41 PM
Boomerchef's Avatar
Default ignition switch won't release the key
I have a '97 4runner with 135,000 miles.
When I put it into Park SOMETIMES the ignition switch refuses to turn all the way off, so that I can take the key out. I have replaced the switch and solenoid in the shift lever, figuring it was worn out.
That hasn't solved the problem. It is totally unpredictable. Sometimes just driving it a few feet or a few miles seems to allow it to release the key. What else could be causing the problem?
Old Apr 11, 2007 | 03:42 AM
rakesh's Avatar
Default RE: ignition switch won't release the key
try replacing the ignition switch.
Old Apr 22, 2007 | 05:53 PM
t4running's Avatar
is an automatic? if so your shift linkage may be a little out of adjustment.you may have to adjust it.
Jeremy Niklason
Feb 26, 2012 11:45 AM
Jean
Nov 11, 2007 10:37 AM
trailerparc
Sep 5, 2007 01:01 AM
unledded90
Jan 25, 2007 02:27 PM
TKellerXIT
Mar 28, 2006 10:57 AM
