Key and ignition problems
Old Sep 4, 2007 | 01:37 AM
trailerparc's Avatar
Default Key and ignition problems
My key won't turn the ignition anymore. I used the spare key (which has only been used a few times) and had no luck either.
Does the ignition have a chip (key) and sensor (ignition switch) that may have failed not allowing me to turn the key?
Is this a known problem? any suggestions on how I might fix this? replace the ignition core....
Thanks for you input.
Old Sep 5, 2007 | 01:01 AM
jtimports's Avatar
Default RE: Key and ignition problems
More info. Year/make/model
if you have a 1988 I will say you need a ignition core, but if you have like a 2005-up I would say get the key checked and the sensor itself.
Jeremy Niklason
Feb 26, 2012 11:45 AM
jpsnky
Feb 7, 2010 08:00 PM
Jean
Nov 11, 2007 10:37 AM
unledded90
Jan 25, 2007 02:27 PM
monster girl
Jan 17, 2006 11:53 PM
