5VZ-FE Cracked Cyndr Heads? Will Replacing cylinder heads and timing belt fix engine
Hi
My engine is 5VZ-FE do i have Cracked Cylinder Heads? what happened: water pump broke and i drove with no coolant 3 miles. then i drove it down the block and engine stalled. sounds like timing belt broke. I think cylinder heads mechanically warped and caused friction and broke timing belt. I don't know much about engine failure. Can someone give me a guess about how this engine failed? Will Replacing cylinder heads and timing belt fix engine? Is cylinder block potentially damaged? I don't think valves crashed into pistons. Thanks for your input! Dave |
