5VZ-FE Cracked Cyndr Heads? Will Replacing cylinder heads and timing belt fix engine
Old 11-09-2019, 12:46 AM
conone's Avatar
Default 5VZ-FE Cracked Cyndr Heads? Will Replacing cylinder heads and timing belt fix engine
Hi
My engine is 5VZ-FE do i have Cracked Cylinder Heads?
what happened:
water pump broke and i drove with no coolant 3 miles. then i drove it down the block and engine stalled. sounds like timing belt broke.
I think cylinder heads mechanically warped and caused friction and broke timing belt.
I don't know much about engine failure. Can someone give me a guess about how this engine failed?
Will Replacing cylinder heads and timing belt fix engine?
Is cylinder block potentially damaged?
I don't think valves crashed into pistons.
Thanks for your input!
Dave
jhawk24
05-16-2012 07:16 PM
leejerryj
06-14-2010 01:48 PM
ram1609
03-01-2008 08:25 PM
bt99runner
02-14-2008 02:08 PM
redent
06-28-2005 04:15 PM
Quick Reply: 5VZ-FE Cracked Cyndr Heads? Will Replacing cylinder heads and timing belt fix engine
