02 sensor causes poor running condition
I recently purchased a 1987 4Runner with a 22RE motor. It didnt have a catalytic convertor or an O2 sensor. I just finished putting both on the vehicle and now it runs poorly.
To diagnose the problem the I disconnected the O2 sensor and sure enough the stumbling/performance issues went away. The O2 sensor is a brand new Bosch sensor. I would like to have a working O2 sensor so my gas mileage will improve and also so that my new catalytic convertor doesnt get destroyed.
My check engine light is NOT on but when I checked the codes I show a Code 11. The following shows the information on code 11 from my Haynes Repair Manual.
Code 11 - Switch Signal
1 AC Switch
2. Throttle position sensor circuit
3. Throttle position sensor
4. Computer
I recently replaced my throttle position sensor because the wrong sensor was installed. I did all the proper adustments and the various resistance tests shows the TPS to be working correctly.
Any suggestions would be helpful.
Thanks,
Gregg
email - gmcgough@yahoo.com
1 AC Switch
4. Computer
Thanks,
Gregg
